How to Create a Manual in Your Language
We recently wrote an article about using external AI in DEVONthink's Help viewer, for example to ask questions about the Help’s content in your language. But it’s sometimes nice to have some references to read offline. So, here’s how to create a small reference PDF document in your language, without needing to use your own AI.
We’ll use DEVONthink and Google Translate as an example.
- Open DEVONthink’s Help viewer via Help > DEVONthink Help.
- Navigate to the In & Out > Sync: Dropbox section.
- Press the Print button at the top of the viewer.
- Press the PDF button in the print dialog and save the file, perhaps named with your language in the name.
- Now open your web browser and open Google Translate.
- Click the Documents link and set your target language.
- Drag and drop the PDF document into the window and press the Translate button.
- After the translation is finished, you can download a new PDF document or view it in your browser.
This allows you to create a custom set of resources in your own language, including the illustrations, that you can read offline at any time. For example, you may want reference PDFs of:
- Using search operators (Appendix > Search Operators).
- Considerations when building a database (Getting Started > Building Your Database).
- How sync works and how to decide which sync method to use (In & Out > Sync Explained).
- How to set up an optimal ScanSnap profile for scanning (In & Out > Going Paperless (Other Options)).
- Troubleshooting steps for handling missing files (Troubleshooting > Repairing a defective database).
You may ask, “Can’t I just translate the entire PDF document from your site?” Yes, you could. But the translated content will not contain links so, for example, the table of contents is only for reading, not navigating. Also, you typically only want information on specific topics, e.g., how tagging works, so translating specific sections makes sense.
As a bonus tip, you can put these reference files in DEVONthink and search them. But you can also use Tools > Merge to consolidate them into one custom “manual” of your own.
